• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    c.schmidt
    Map 3D 2012 Window looses focus when using Acad-functions
    131 Views, 2 Replies
    07-10-2012 02:00 AM
    hello community!
    i have a problem.
    When i use standard Acad-functions or even simply
    select an object like a polyline from land-survey,
    the "ribbon" changes to the corresponding Topic of the object,
    and the Map3D window looses its focus. (normal windows-mouse-cursor is displayed,
    not the AutoCAD crosshair). After clicking in Map 3D window again, crosshair reappears,
    and work can continue.
    It doesn't matter if Map3d-windows is in windowed mode or fullscreen,
    it also doesn't matter if the windows is only on one of my 2 monitors or on both.
    didn't have this problems using Topobase Client 2009,2010,2011...
    but since 2012 few problems evolved... (drawing-order-bug, memory-leak problem etc. etc.)
    quality of the software product Topobase or "Map 3D" is getting worse and worse....
    Please use plain text.
    Re: Map 3D 2012 Window looses focus when using Acad-functions
    07-10-2012 12:26 PM in reply to: c.schmidt
    do you have installed the latest service-packs?
    have you opened the property-window? ...and if so does the problem also occure if you have the poperty-window closed or minimized or undocked?
    - alfred -
    Alfred NESWADBA
    Member
    c.schmidt
    07-11-2012 02:16 AM in reply to: alfred.neswadba
    Alfred, you're my man.
    After closing the properties window (which was fixed displayed under the legend on the right)
    the issue is gone.
    THX so much man!
