• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Contributor
    Map 3D 2011 grid and graticules
    599 Views, 12 Replies
    05-20-2010 11:28 AM
    Does anyone know how to modify the grid feature to display the coordinates in the system you are actually using?
    Cindy
    Please use plain text.
    Active Member
    Re: Map 3D 2011 grid and graticules
    05-21-2010 09:06 AM in reply to: cynwalker
    R u trying to plot and/or disply the coord system grid at a specified incremet ?
    I'am also wondering about this....no results...
    Valued Contributor
    05-21-2010 09:28 AM in reply to: cynwalker
    I'm trying to plot/display the grid in a specific coordinate system, say, UTM NAD 27 or State Plane.
    Valued Contributor
    05-26-2010 01:58 PM in reply to: cynwalker
    Okay, I'll bite. How do we add graticules to a layout? I've been poking around and can't seem to find it anywhere.
    *Murph
    05-26-2010 02:07 PM in reply to: cynwalker
    2011, on the layout tab of the ribbon, after you set up a layout and make it
    active.
    Murph
    http://map3d.wordpress.com/
    "Gary_Braun" wrote in message news:6397955@discussion.autodesk.com...
    Valued Contributor
    05-26-2010 02:09 PM in reply to: cynwalker
    Ah, the cursed ribbon, no wonder I couldn't find it. Thanks again Murph.
    Active Member
    05-27-2010 09:00 AM in reply to: cynwalker
    Is this a New 2011 Map 3D addition? Does this exsist in 2010...2008..Map releases..Im blocked out of the Link Posted....
    Please verify....I have yet to install my 2011 version...
    I have yet to locate this in my current 2010 or past 2008 release
    *Murph
    05-27-2010 11:14 AM in reply to: cynwalker
    It's a 2011 feature only.
    Murph
    "KellyMason3179" wrote in message news:6398662@discussion.autodesk.com...
    Valued Contributor
    05-27-2010 11:20 AM in reply to: cynwalker
    Hi Murph,
    Well, since you didn't answer the original question can I assume you have to show the grid in WGS84?
    Cindy
    Active Member
    05-27-2010 11:26 AM in reply to: cynwalker
    Murph : I thank you and my PC also thanks you !
    Now I must upGRADE...just when i thought it was safe in the 2010 waters
