• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Distinguished Contributor
    Accepted Solution
    Map 2010 Export ??
    358 Views, 16 Replies
    09-01-2009 07:42 AM
    I recently upgraded to 2010. When i try to Export my .shp files i always get "0 object(s) of 1141 selected, exported in 0 sec(s)."
    I use the map, tools, export command and use my same .epf files that i created for all of my .shp files from 2008.
    I've even tryed making completely new .epf files to download and it still gives me the 0 objects exported on the command line.
    But if i save the .dwg back and open it in 2008, the export works fine??
    Any ideas why it will not export in 2010??
    Thanks.
    Please use plain text.
    Re: Map 2010 Export ??
    09-01-2009 06:17 PM in reply to: cloquet
    What types of objects are you exporting? SHP files can only store one geometry type (point/line/polygon) per file.
    Are you trying to export polygons from polylines? There's an option to specify that closed polylines are treated as polygons.
    - Jackie
    09-02-2009 07:48 AM in reply to: cloquet
    I have point objects & polyline objects and none of them will export.
    i get the same "0 files export" message in the command line for everything
    yasin2ray
    11-29-2011 11:54 AM in reply to: cloquet
    Did you ever get this resolved, Cloquet?
    I am having the same issue - the same error message and I've tried exporting lines, polylines, etc. I've tried checking the box "treat closed polylines as polygons". I tried converting my coordinate system on the final tab. I tried all forms of object selection.
    I'm still getting that error message. Mine is this: "0 object(s) of 1313 selected. Exported in 0 sec(s)."
    Any ideas?
    Thanks for any help from anyone. This topic hasn't received enough attention - first posted in 2006!
    Anna
    AutoCAD Civil 3D 2010
    *Expert Elite*
    antoniovinci
    11-29-2011 12:50 PM in reply to: yasin2ray
    Start over with a new empty file, draw ONE line and export it to shape: have you the same issue?
    Valued Mentor
    11-29-2011 01:23 PM in reply to: antoniovinci
    op stated was exporting a .shp file, not to a .shp file.  which is it?
    dave
    11-29-2011 03:39 PM in reply to: cloquet
    Is there a database link involved in the export, check that it is recognizing the link if you are exportiing data with the file.
    John
    *Expert Elite*
    antoniovinci
    11-29-2011 11:03 PM in reply to: JohnPM
    It doesn't matter, sir.
    Even if the database link is dead, Autocad will be able to export the geometry to a shapefile, without those Object Datas.
    yasin2ray
    11-30-2011 07:57 AM in reply to: antoniovinci
    @ antoniovinci,
    I tried your suggestion. I drew a line in a new document and gave it an elevation as if I were drawing contours. I tried to export using the command "mapexport" and I got the same error message.
    Interestingly, yesterday evening I found a post that suggested the command "mapexport4". I tried that and I was able to export a shapefile however, I couldn't figure out how to include Elevation information in the export. The dialog box for "mapexport4" is completely different than the dialog box for "mapexport".
    With regard to the other suggestion, I am not using any database with this file at this time.
    Any info on the specifics of these two export methods?
    Anna
    *Expert Elite*
    Murph
    11-30-2011 03:11 PM in reply to: yasin2ray
    yasin2ray wrote:
    @ antoniovinci,
    Anna
    What version are you using and is it just AutoCAD Map3D or Civil 3D? You posted back in May in the 2008 version forums are you still on 2008 or have you upgraded?
    Murph
    Supportting the troops daily.
