• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    *PE, James Gabriel
    Managing Aerial Imagery - Raster Ugh!
    89 Views, 3 Replies
    11-26-2002 03:48 AM
    I am experiencing unhandled access general errors as i work with a drawing
    file intowhich i have inserted about a third of the counties aerial photos,
    when its working the mosaic is quite a usfull tool. Should/could i be more
    efficient with my memory by xrefing the MR Sid images?
    thank yall in advance
    JimG PE
    County Engineer
    Please use plain text.
    *Wilson, Neil
    Re: Managing Aerial Imagery - Raster Ugh!
    11-26-2002 06:53 AM in reply to: *PE, James Gabriel
    I don't think you would gain anything by Xrefing. However, I would recommend
    that you turn off image display for all images by default. This way you
    would not have huge load times and you can turn on only those images that
    you need for the area you are working on.
    You can toggle image display off and on via the properties dialogue.
    ames Gabriel PE" wrote in message
    news:4EA21704705F0A449F08543E30409E8C@in.WebX.maYIadrTaRb...
    photos,
    more
    > JimG PE
    > County Engineer
    *Jaquith, David
    11-26-2002 09:27 AM in reply to: *PE, James Gabriel
    Jim,
    Go to Map>Image>Options>Memory and increase the memory to allocate to
    images. You probably don't want to make it more than 1/2 of your total
    physical memory.
    David
    "James Gabriel PE" wrote in message
    photos,
    more
    > JimG PE
    > County Engineer
    *Nealey, David
    11-28-2002 05:13 AM in reply to: *PE, James Gabriel
    One operation that you may consider is to mosaic all of the images with an
    application such as ER Mapper or ERDAS Imagine and then compress the
    finished mosaic using either ECW or MrSID. With ER Mapper and Imagine you
    can also color balance the images, which will make the mosaic look like a
    single photograph.
    The ECW or MrSID files will work just fine once you configure your computer
    for large raster data until you try printing the entire dataset. Both
    compression algorithms will expand the image to full Tiff size for printing.
    You will need a RIP engine to deal with that issue. ER Mapper includes a
    RIP engine but I am not sure how well it works with Map, or by itself for
    that matter. But you can have the ERM folks send you a CD with ER Mapper
    for evaluation. ERDAS (now part of Leica) may do the same with Imagine
    evals. The point is that there are two parts to the issue of raster data
    in a GIS: 1) viewing large amounts of raster data, and 2) printing the data.
    You may only be interested in viewing the data now but eventually you'll
    want that large wall map showing your work. Make sure that the solution you
    select serves both purposes.
    If you don't want to deal with an image processing program then consider
    outsourcing the creation of a color balanced, compressed mosaic of your area
    of interest. A remote sensing grad student at a university or college
    should also be able to do this for you.
    David N.
    photos,
    more
    > JimG PE
    > County Engineer
