• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    Make thematic map of external data linked to labels
    93 Views, 2 Replies
    11-30-2012 07:39 AM
    Ok, so in map3d I can use
    attach data source
    connect data source
    define link templates
    generate data links
    (in that order) to attach data in an excel spreadsheet to a bunch of text objects in my drawing.  The spreadsheet is keyed on the text in the text objects.
    However - I can't then make a thematic map based on this data!  Using the thematic map tool, with either "data" or "sql" expression, acad reports that "No link templates exist".  Which seems odd because I already linked the data in using one.
    Can anyone solve this problem for me?
    Please use plain text.
    antoniovinci
    Re: Make thematic map of external data linked to labels
    11-30-2012 11:18 AM in reply to: zcrispin0.autodesk
    Which ODBC driver did you use to link your DWG objects to the Excel records?
    Member
    12-03-2012 06:16 AM in reply to: zcrispin0.autodesk
    Microsoft OLE DB Provider for ODBC Drivers (well this is what it says in properties for the attached data source anyway)
