AutoCAD Map 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: MAPEXPORT Xref
- Highlight
- Email to a Friend
Thanks, but will this allow the drawings to be automatically updated in my map3d drawing if our engineers modify the drawing that was attached?
Re: MAPEXPORT Xref
- Highlight
- Email to a Friend
Unfortuantely, No - drawing queries are "static." so you'd have save the query and then re-execute each time. Also, for whatever reason, drawing queries do NOT pick up / speak AEC object language - you won't get Civil3D surfaces, alignments, points, parcels, etc. Forwarned is foreamred ![]()
TdH
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
Re: MAPEXPORT Xref
- Highlight
- Email to a Friend
Peter_NDNG wrote:Thanks, but will this allow the drawings to be automatically updated in my map3d drawing if our engineers modify the drawing that was attached?
Not any more than the exported file that you export. If you save the query to an external query you can open a blank dwg and run that query to get all new updated objects.
Supportting the troops daily.
Re: MAPEXPORT Xref
- Highlight
- Email to a Friend
thepworth wrote:Unfortuantely, No - drawing queries are "static." so you'd have save the query and then re-execute each time. Also, for whatever reason, drawing queries do NOT pick up / speak AEC object language - you won't get Civil3D surfaces, alignments, points, parcels, etc. Forwarned is foreamred
TdH
Saving the query as an extrenal query makes it easy, also those AEC objects (Civil3D) don't export either with the mapexport command.
Re: MAPEXPORT Xref
- Highlight
- Email to a Friend
Thanks all, I've got it all working. When I attach an xref I need to do it a as an attachment rather than an overlay. Then I set up ETRANSMIT to insert exrefs under transmittal setups. Now I just open the .dwg with ArcGIS and use the CAD to Geodatabase tool, and BaDOW!
our asbuilts are in in a .gdb which we can push out to ArcServer and to our FLEX viewer for our guys in the field.
Thanks a lot for the help everyone.
Now I just need to work on getting all this scripted. Thank goodness lisp looks really easy.
