• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Peter_NDNG
    Re: MAPEXPORT Xref
    04-02-2012 06:47 AM in reply to: Murph
    Thanks, but will this allow the drawings to be automatically updated in my map3d drawing if our engineers modify the drawing that was attached?
    Please use plain text.
    Distinguished Mentor
    thepworth
    Re: MAPEXPORT Xref
    04-02-2012 07:31 AM in reply to: Peter_NDNG
    Unfortuantely, No - drawing queries are "static." so you'd have save the query and then re-execute each time.  Also, for whatever reason, drawing queries do NOT pick up / speak AEC object language - you won't get Civil3D surfaces, alignments, points, parcels, etc.  Forwarned is foreamred :smileywink:
    TdH
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    Murph
    Re: MAPEXPORT Xref
    04-02-2012 03:02 PM in reply to: Peter_NDNG
    Not any more than the exported file that you export. If you save the query to an external query you can open a blank dwg and run that query to get all new updated objects.
    Murph
    Supportting the troops daily.
    Murph
    Re: MAPEXPORT Xref
    04-02-2012 03:04 PM in reply to: thepworth
    TdH
    Saving the query as an extrenal query makes it easy, also those AEC objects (Civil3D) don't export either with the mapexport command.
    Murph
    Peter_NDNG
    Re: MAPEXPORT Xref
    04-03-2012 12:16 PM in reply to: Murph
    Thanks all, I've got it all working.  When I attach an xref I need to do it a as an attachment rather than an overlay.  Then I set up ETRANSMIT to insert exrefs under transmittal setups.  Now I just open the .dwg with ArcGIS and use the CAD to Geodatabase tool, and BaDOW! :smileyvery-happy:our asbuilts are in in a .gdb which we can push out to ArcServer and to our FLEX viewer for our guys in the field.
    Thanks a lot for the help everyone.
    Now I just need to work on getting all this scripted.  Thank goodness lisp looks really easy.
