• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    kburgy
    Lwpolyline not filling
    102 Views, 3 Replies
    07-09-2012 04:11 PM
    I have a drawing that I'm having issues with, all of the Lwpolyline that we have in our drawings are not filling in the arrow part.
    I have checked to verify that the fill is on, fillmode is on, Apply solid fill is on on the Display tab of options.
    It isn't a leader arrow, but I did verify that the Arrowheads are all selected to Closed filled.
    Regen does nothting as well.
    Any other thoughts.
    Please use plain text.
    *Expert Elite*
    Re: Lwpolyline not filling
    07-10-2012 12:24 PM in reply to: kburgy
    polyline-widths are not visualized as filled when you don't look vertical onto the object-orienation.
    Try command _UCS and then object ==> click onto the poly (that creates a ucs that is parallel to the entity-orientation), then run command _PLAN and option for current ucs. ==> is the lwpoly now filled?
    If not please upload a DWG and not a PDF as we can look more into details of your object and ucs and sysvars.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    New Member
    kburgy
    07-10-2012 12:57 PM in reply to: alfred.neswadba
    That did not seem to work. our UCS icon never changes, I have attached a portion of the problem file.
    *Expert Elite*
    07-11-2012 05:06 AM in reply to: kburgy
    command _PLAN with option _W
    Or if you have the viewcube visibile: click on "TOP"
    - alfred -
    Alfred NESWADBA
