• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Member
    Local license vs network license
    227 Views, 9 Replies
    01-23-2013 05:59 AM
    We want to check and be sure that our licenses are correct for our company.
    We have discovered that some of our HKLM\Software\Autodesk\Serialnumber is marked as 000-00000000 which might be considered as trial? At the same time, if we go to Help > About it shows the correct serial as shared from our FlexLM licenses.The key StandaloneNetworkType is set to 3 which should be Network License mode. Also, sometimes is StandaloneNetworkType set to '0'. So I am not sure what is safe here.
    Can anybody inform us about how we ensure that our setup is legal?
    Please use plain text.
    DarrenP
    Re: Local license vs network license
    01-23-2013 06:04 AM in reply to: HAL0
    only way to check is to verify your serial numbers with your reseller
    thats the easiest
    Active Member
    01-23-2013 06:11 AM in reply to: DarrenP
    well checking our install and distribution method might be a long process so I hoped for some help here.
    DarrenP
    01-23-2013 06:16 AM in reply to: HAL0
    what exactly are you trying to determine?
    seat count?
    serial number?
    products & versions?
    Active Member
    01-23-2013 06:18 AM in reply to: DarrenP
    im trying to ask if its legal to have a local registry 000-00000000 as long as help > about shows the correct serial and you are licensed.
    DarrenP
    01-23-2013 06:21 AM in reply to: HAL0
    as along as the product has the correct serial number you should be fine
    Active Member
    01-23-2013 06:23 AM in reply to: DarrenP
    thanks. do you know if its legal to use older serials locally? we have older products like 2011-products (we are allowed to use 2010-2013 products in our license). can we use serials from 2011 locally or do we have to replace them?
    DarrenP
    01-23-2013 06:25 AM in reply to: HAL0
    you use the 2011 serial number
    as along as you aren't exceding the number of license as you own
    Active Member
    01-23-2013 07:03 AM in reply to: DarrenP
    thanks. well reading about this seems not so easy as you type here... when companies like http://www.scottandscottllp.com/main/Preventative_Step_to_Reduce_Exposure.aspx seem to specialize in this
    have you ever been involved in a autodesk license revision of a company?
    DarrenP
    01-23-2013 09:00 AM in reply to: HAL0
    no i have not
