AutoCAD Map 3D
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Linetype changing scales
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
115 Views, 1 Replies
06-15-2012 02:48 AM
I am using Map 3D 2013
I have several drawings in which I want to use a linetype (centrex2) at a specific scale. The scale setting is exactly the same in all the drawings but in some the linetype is coming out at different scales, all larger, but not the same or to a set factor. All the entities in question are polylines (2d).
I have checked in all drawings that:
- global scale factor and current object scale in the linetype manager are the same (1.0)
- drawing units are the same (unitless)
- ‘use paper space units for scaling’ is always deselected
- linetype generation is always enabled
Any other suggestions gratefully received
Re: Linetype changing scales
Options
- Highlight
- Email to a Friend
06-19-2012 09:29 AM in reply to:
GrahamSherwood6686
Hi Graham,
Do you mind sending a drawing that shows the issue?
Ideally, use eTransmit to create a pack of files that are used by this drawing (in case you are using a custon linetype).
Cheers,
Luciane
Luciane Conceição
Product Support Specialist
Autodesk, Inc.
