• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Distinguished Contributor
    bingeomatics
    Accepted Solution
    Line style
    310 Views, 15 Replies
    08-25-2012 12:12 AM
    Hello!
    Who can help me? I want to creat a line style for feature objects (line object) wich symbols only on the vertex of the line. How can I do it?
    Binnat Khalilov
    Please use plain text.
    Valued Mentor
    Re: Line style
    08-25-2012 04:46 AM in reply to: bingeomatics
    one way shown in the attachments.  is this for display only or some other reason?
    Valued Mentor
    Re: Line style
    08-25-2012 04:52 AM in reply to: parkr4st
    How I did the display manager. two uses of same shp file #3.  and with the line work layer off #4.
    You could also get the nodes at the ends of lines as points and style the points in a seperate layer.
    dave
    bingeomatics
    Re: Line style
    08-26-2012 04:02 AM in reply to: parkr4st
    Thank you, parkr4st, for to try help me!
    But I don't want to creat seperate layers. I want to do it only on liner layer. An example, I want to creat a power trust which was shown  on the picter.  I can to make a liner layer which symbols (blocks). But in AutoCAD Layer Style Manager we can do it by giving interval between symbols. If I want to give a symbol only for the vertex of the line, it is impossible. Have any way to creat style like that?
    Power trust
    Binnat Khalilov
    Valued Mentor
    Re: Line style
    08-26-2012 04:44 AM in reply to: bingeomatics
    set style like this if i understand what you want
    bingeomatics
    Re: Line style
    08-26-2012 09:48 PM in reply to: parkr4st
    No, this method, which you show, inserts the symbol only to the start and end vertexes. But I need to insert it to all vertex
    Binnat Khalilov
    Valued Mentor
    Re: Line style
    08-27-2012 12:59 AM in reply to: bingeomatics
    mapimport, explode the poly lines to lines, new sdf or shp and apply the style.
    dave
    *Expert Elite*
    antoniovinci
    Re: Line style
    08-27-2012 01:48 AM in reply to: bingeomatics
    Without creating any new linetypes, here's  a free tool doing what you wish, sir.
    bingeomatics
    Re: Line style
    08-27-2012 02:25 AM in reply to: parkr4st
    But I thing that is not normally cartographic method. Because, every power trust must be one whole polygonal object and one raw in database table. Thank you very much, parkr4st, for trying to help me. I understand that in AutoCAD Map have not cartographic (styling) function like that......:smileyembarrassed:
    Binnat Khalilov
    Valued Mentor
    Re: Line style
    08-27-2012 03:46 AM in reply to: bingeomatics
    Binnat
    what is a power trust so I will know in the future?  i haven't heard the term.
    dave
