AutoCAD Map 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
LINETYPE PROBLEM... NEED HELP!!
- Highlight
- Email to a Friend
Hey,
I have a massive problem with my autocad map 3d's linetype scale...
Problem is caused from creating an primary viewport "construction plan", then creating a second viewport "detail plan" and zooming in on the detail plan viewport.
My line type in the detail plan turns into ------ LV ----- as apart from the normal size of -----LV-----.
I've tried everything form psltscale, lt scale, msltscale (i think), audit, recover, basically everything i could.
NOTE: This problem is only oon my pc, and none of the other pc's in the offfice do this. I use classic autocad and have customised my buttons etc.
Thanks.
Enrico
Re: LINETYPE PROBLEM... NEED HELP!!
- Highlight
- Email to a Friend
Standard usage is to set PSLTSCALE = 1, MSLTSCALE = 1, and LTSCALE = 1 or LTSCALE = 0.5. Then linetypes print the same in both primary and detail viewports.
- Highlight
- Email to a Friend
HI,
I've tried all of those line type settings and the attached picture is the outcome. Usually, as standard the LV in the attched picture is a lot larger. The only way to reverse it to hold ctrl+z unitll the most of the work is reversed.
Cheers
- Highlight
- Email to a Friend
hi again,
attached is the lv line type from another drawing prior to the pronlem occuring.
Cheers,
- Highlight
- Email to a Friend
Check your text style and font used for the Standard text or what ever the line type definition is using.
Supportting the troops daily.
- Highlight
- Email to a Friend
Is there a way to get the linestyle details? I mean, extract the line type style from the drawing. I've tried through design centre.
Reason for this is i will try to make another line type and just replace it.
Cheers
- Highlight
- Email to a Friend
In "Manage Text Styles..." under Annotate tab/current txt style, Standard size should be uncheched for Annotative and Height should be 0.000.
- Highlight
- Email to a Friend
I know I am resurrecting an old post, but just wanted to thank Mr. Dan and Sinc for posting their responses and that screen snapshot. Thank goodness for Google, too. I had learned about LTSCALE and PSLTSCALE before, but never knew about MSLTSCALE. The real happiness came when I discovered my STANDARD text height was set to 25 in my Text Style dialogue box and it was causing my OH E and W linetypes to be unuseable. Thanks again.
-Harold
