LABEL OBJECT DATA
LABEL OBJECT DATA
Message 1 of 39
LABEL OBJECT DATA
I'm not an everyday map user so I'll try to explain this the best I can and hope someone understands it. I generally stay in Civil 3D (2011).
So, I used the "mapinsert" command to insert a shape file from Arc GIS which consitsed of city property lines. I also wanted to include some object data (owner, address, name, etc...). So far, so good. The property lines came in as closed polylines just like a wanted. So when you select one closed polyline all the object data displays in your Properties pallete for that particular "property line". My question is can you add this object data as a label/text to each closed polyline (property)? Ive been messing around with inserting annotation but so far I got nothing. In the end I would like the property owner name listed within the property lines as text. Seems pretty simple to me. Thanks
Replies (38)
Message 21 of 39
albionpjl
Thank you, it did work the second time, but unfortunately when I explode the new labels they turn back into the tag name.
 I have to explode them because the programme that must use this file when finished cannot read autocad blocks correctly. It dumps them all at 0,0.
For anyone who  doesn't need to explode this would be a better solution than the other one given in this thread, but for my purposes, the longer workaround is what it will have to be.
Unless there is a way to explode the blocked text without it changing into the tag name?
Message 22 of 39
foxeec
Try the 'burst' command.
when I tried it, it kept the data, and the location.  When selected, it then says it's just text.
Lorrie
Message 23 of 39
albionpjl
Thank you very much.
That has worked.
I think I need to make myself a new toolbar with those commands. 🙂
Message 24 of 39
Thanks .
its realy working .
thanks again dear
Message 25 of 39
I can not see the data fields that are in the data table in the expression chooser.  There is no instance of the data fields I am looking for in the Properties or Object Properties lists at all.  Any ideas?  Beyond that this works well.  I can get Map to label whatever is in the list, I am just not seeing the colum names that are in my data table.
Pete
Message 26 of 39
Antonio, your method is brilliant! We do use Map3D and Civil3D occasionally on our architectural practice and often deal with GIS conversions to CAD. We always struggled to convert GIS text to CAD text format, it was always a long winded process! Your method worked very well, you saved us a lot of hours of work! Thank you!
Message 27 of 39
dkoppes
...is there any way to control the decimal places for length. It is displaying a number like this 167.354589...when all I want is the whole number...167.
...also, is there a way to add text to end of a value?...It is displaying 336 AL, but I want to add a P at the end of the value...
Can you help?
Message 28 of 39
dkoppes
Can you help?
Message 29 of 39
antoniovinci
Try to type LUPREC and set to 0, sir.
Message 30 of 39
dkoppes
I am trying to extract "OBJECT DATA" from ESRI polyline that I used ACAD MAP IMPORT to bring into ACAD MAP 3D....
I figured it out   (STRCAT (RTOS .LENGTH 2 2) “‘ ” )
I am now trying to add the letter "P" at end of the value...but it's not working for me....(STRCAT (:PRIMSIZE@OHPRIM) "P")
What am I doing wrong ???
See attachment
Message 31 of 39
olivier.eckmann
is PRIMSIZE a real value or a character or an integer
if real => (STRCAT (rtos :PRIMSIZE@OHPRIM 2 0)  "P")
if char=> (STRCAT :PRIMSIZE@OHPRIM  "P")
if int => (STRCAT (itoa :PRIMSIZE@OHPRIM)  "P")
Olivier
Message 32 of 39
dkoppes
Thanks Olivier,
Here is another one for you...
I have a dynamic block that extracts data from imported ESRI lines in ACAD MAP 3D.
When I pick line to insert block, sometimes it rotates the right way and sometimes it rotates the wrong way. (See attachments)
Is there any way to align block so the text is not upside down. I tried using the "FLIP" parameter & action settings but it does not work.
Thanks in advance for your time !
Don
Message 33 of 39
Murph_Map
A dynamic block as in (plain) AutoCAD or a MapAnnoBlock? I think what is happening is the direction the line you are labeling is drawn in that direction. Back when I was labeling span length and conductors we had a lisp that checked the angle and if it was greater than 180 we subtracted 180 then used that angle to label. Of couse the lisp allowed the user to pick on what side of the line to place the text (label).
Murph
Supporting the troops daily.
Message 34 of 39
Thank you! This worked well for me.
Message 35 of 39
brandyrodriguez
Lorrie,
 You are amazing! Thanks for posting this 🙂
Message 36 of 39
wish I would have known about this workflow years ago
thank you Lorrie
Message 37 of 39
Mark_Castle
@foxeec wrote:
Another way to go about it:
First, use 'Mapimport' to bring in your closed polylines with object data.
then:
1- 'mapanntemplate'  (don't enter the quotes - you'll get a dialog box, when you hit ok, it'll open the block editor)
2- 'mapanntext' (then I hit 'enter' for new text.  You'll get a dialog box asking for infomation for you to supply for the label.  Under the 'value' box, you can specify a field from your object data to be supplied.  When it asks for the insertion, i always use 0,0; which inserts the text right where i need it inside the polylines.).  At that point, i close the block editor, saving my changes on the way.
3 - 'mapanninsert' (check the template you created, select your polylines, and voila!  Labels!
if the labels need to be tweaked, use the 'mapanntemplate' again, to edit the template contents, such as size, layer, etc.; then run the 'mapannupdate' command to have those changes reflected.
Lorrie
This is absolutely fantastic!! I'm so glad I found this post. Thank you!
Mark Castle
Win 10 64-Bit, Thinkpad P50
16 GB RAM; Core i7-6820HQ; Quadro M1000M
Message 38 of 39
rstahly
Observer
Observer
Creating an annotation template would work for what you are wanting to do. Or as somebody else has stated, connect the data and edit the theme to label property owners. By the way you explain where you are currently at the annotation template is the most appropriate without re-inventing the wheel
Message 39 of 39
Brilliant that worked wonders thanks. i had the same problem.
