• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    Issues with Map 3D and Arcview
    564 Views, 5 Replies
    11-05-2009 06:53 AM
    So every time I open Arcview Autocad Map 3D runs some sort of install or configuration. It usually runs about 4 times and then lets me into Arcview. I just recently installed Map 3D so I've seen this issue. I'm trying a repair on Acrview right now to see if that helps the issue. Has anyone had this same issue?
    Please use plain text.
    *Murph
    Re: Issues with Map 3D and Arcview
    11-06-2009 09:02 AM in reply to: xxdrvxx
    Try this :
    http://rand.com/imaginit/1/rss/viewitem.asp?feedid=BLOGS_GIS_ALL&guid=639
    Murph
    http://map3d.wordpress.com/
    "xxdrvxx" wrote in message news:6284131@discussion.autodesk.com...
    this same issue?
    Valued Contributor
    06-09-2010 08:37 AM in reply to: *Murph
    Hi Murph,
    I recently updated my MAP 2010 with the new service pack released a few weeks ago, and all of a sudden I started getting MAP trying to install and configure itself if I opened ArcViewGIS 9.3.1.  I tried the above link but it appears that the Blog you referred to isn't avaiable any longer.  This issue is starting to drive me nuts...it seems like there should be something else written on it but I can't seem to find much else but this posting.
    Active Member
    06-11-2010 11:17 PM in reply to: xxdrvxx
    I remember running into this issue back in 2008. I would go to start a program (in my case it was Papervision) and it would initialize the autocad installer. After "x-ing" out of the window several times, i'd finally get the program to load. I don't remember the fix right now, but I seem to recall making a note of it and filing it at work. I'll have to look it up Monday.... seems it had something to do with allowing the installer to start up, then bring up the task manager (control+alt+delete) and then stopping a process. But again, I'm not sure. I'll email this thread to my work email as a reminder for me to look into my notes files for the fix. Perhaps with this "bump" someone else will have a remedy for you before then.
    Valued Contributor
    06-12-2010 10:06 AM in reply to: rmacan
    From the link:
    The temporary solution to suppress the the installer dialog from popping up is as follows:
    In windows Explorer navigate to:
    C:\Documents and Settings\All Users\Application Data\Autodesk\
    Copy the Geospatial Coordinate Systems folder
    Paste the folder to the same location
    Once the copy is complete, rename the folder to:
    Geospatial Coordinate Systems Temp
    Again, this is a temporary solution, but it is a simple fix to prevent the installer dialog from always starting.
    Murph
    http://Map3d.wordpress.com
    New Member
    carie1976
    11-02-2010 01:05 PM in reply to: xxdrvxx
    It seems strange that this would fix the problem but it worked on my machine.  Thank you for posting this information it was very helpful.
    Carie
