AutoCAD Map 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Intersecti ng GIS Parcel Data with an alignment ROW
- Highlight
- Email to a Friend
I am a beginner with AutoCad software, and I am currently using Civil 3D/Map 3D 2009.
I imported a shp. file containing property information (owner, area, address, etc), and also imported an alignment row as a sdf. file. The row is a closed polygon.
My goal is to intersect these two types of data so that I end up with information on the number of properties effected by the row.
Is civil 3d 2009 capable of doing this? If so, how? I found a youtube video on using the 'Offset Alignment' command with Civil 3D 2010, however, is not the same for 2009.
Any help would be appreciated, Thanks.
Re: Intersecti ng GIS Parcel Data with an alignment ROW
- Highlight
- Email to a Friend
With Map3D you need to use data connect and bring the parcel shp file and ROW sdf file in as FDO features, then use the intersection option on doing a overlay analysis. As for the ROW offset you need to ask in the Civil3D forum.
Supportting the troops daily.
- Highlight
- Email to a Friend
I like Murph's overlay suggestion - if you save the result as a shapefile, you can open the .dbf in Excel or Open Office and pull any stats or do math there.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
- Highlight
- Email to a Friend
intersection does give 100% right answer. exceptions are where the ROW crosses multiple sections of one property i.e L S U Z shaped parcels, rivers & roads with S curves, which create two or more new polygons in the intersect file. This inflates the number of affected parcels from the original parcel layer.
intersect sdf file; data table and select all, copy and paste to excel for data analysis. is that acceptable for this case?
Dave
- Highlight
- Email to a Friend
I meant does not give 100 % right answer. ![]()
dave
- Highlight
- Email to a Friend
It's a bit of a hassle, but you could take the original file and the overlay result, join the two using the feature ID as the key in a one to many join - that will get all the data in one place, but you'll still need to massage it (possibly) in Excel.
Nate Moore, GISP
Global Services
Autodesk, Sarl
- Highlight
- Email to a Friend
roundabout
intersect source ROW Overlay Parcel result is Row_intersect
Theme the Row_intersectSDF using the FeatId2 as individual values. the number of rules = the number of parcels the ROW crosses.
Dave
