• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Distinguished Contributor
    ACADuser
    Internal Error: Failed to get media from layout
    570 Views, 5 Replies
    07-09-2007 08:56 AM
    Hi everyone,
    I'm having problems with detaching images from my drawing. When I try to detach the images the following error shows on the command line;
    "Internal Error: Failed to get media from layout"
    "filename"
    The remain attached to the drawing, layers are on and thawed. Wait a minute...........just realized the layers are locked....duh, I unlocked them and the images can be detached now !
    Thought i would just go ahead and post this, in case someone else comes across the same problem.
    ACADuser
    Dell Precision T5500 Workstation
    Windows XP Professional SP3
    Dual Quad Core Intel Xeon Processors E5540 2.53GHz,8M L3,5.8GT/s,turbo
    4GB, DDR3 Memory, 1066MHz, ECC (4 DIMMS)
    1.5GB NVIDIA Quadro FX 4800, DUAL MON, 2DP & 1DVI
    160GB, 3.0Gb/s, 16MB Data Burst Cache,SATA2,10K RPM Hard Drive
    16XDVD AND 16XDVD+/-RW
    Please use plain text.
    *Expert Elite*
    rkmcswain
    Re: Internal Error: Failed to get media from layout
    06-27-2008 09:52 AM in reply to: ACADuser
    Thanks - this did help someone.
    New Member
    02-13-2009 08:49 AM in reply to: ACADuser
    and someone else too! Thanks again Edited by: balsumeet on Feb 13, 2009 4:49 PM
    12-01-2009 04:46 PM in reply to: ACADuser
    Thanks for posting. Helped me out.
    Active Member
    06-11-2010 01:49 PM in reply to: ACADuser
    Helped me out as well.
    New Member
    09-30-2010 09:20 AM in reply to: ACADuser
    Thanks!  Still useful!
