AutoCAD Map 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Install of AutoCAD Map 3D 2013 Stalls at Autodesk Material Library 2013
- Highlight
- Email to a Friend
Hi All, has anyone come across this installed 32bit AutoCAD Map 3D 2013?
My install fails at the AML 2013 - Low Rez and I can't install Map at all.
I don't think there is an option to no install the Material Library...
Here is my log file from a few minutes ago...
2012/5/29:12:31:55 gluckett PRAGUE Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Map_3D_2013_
2012/5/29:12:32:47 gluckett PRAGUE Install Autode
Re: Install of AutoCAD Map 3D 2013 Stalls at Autodesk Material Library 2013
- Highlight
- Email to a Friend
Is your virus protection disabled while you install? It may be the culprit.
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
- Highlight
- Email to a Friend
I wish it were that easy!
I tried installing that library manually:
C:\Autodesk\AutoCAD_Map_3D_2013_English_Win_32bit\
But it still Fails:
I wish I could tell AutoCAD Map 3D 2013 not to install this component when installing and I would be golden.
- Highlight
- Email to a Friend
More details: this is where the install of the Materials fails:
InstallShield 16:42:06: Invoking script function Luc_Install
InstallShield 16:42:13: CallScriptFunctionFromMsiCA() ends
InstallShield 16:42:13: Cleaning up temp file C:\Users\gluckett\AppData\Local\Temp\{4C4693A5-520
CustomAction LaunchLucEXE_2012 returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
Action ended 16:42:13: InstallFinalize. Return value 3.
Action ended 16:42:17: INSTALL. Return value 3.
Action ended 16:42:17: ExecuteAction. Return value 3.
Action start 16:42:17: SetupCompleteError.
Action ended 16:42:32: SetupCompleteError. Return value 2.
Action ended 16:42:32: INSTALL. Return value 3.
=== Logging stopped: 5/29/2012 16:42:32 ===
MSI (c) (6C:70) [16:42:32:189]: Product: Autodesk Material Library Base Resolution Image Library 2013 -- Installation operation failed.
MSI (c) (6C:70) [16:42:32:189]: Windows Installer installed the product. Product Name: Autodesk Material Library Base Resolution Image Library 2013. Product Version: 3.0.13. Product Language: 1033. Manufacturer: Autodesk. Installation success or error status: 1603.
- Highlight
- Email to a Friend
1603 has sometimes to do with Framework (so install Framework 4 before starting AutoCAD-installation) or with access-rights, so install AutoCAD with another user-account that has full local admin-rights and UAC is switched off and the SETUP.EXE is started with the right-mouse-button ==> "Start as Administrator".
Also verify what processes and services are currently running during installation, e.g. Antivirus-software (as already mention) or some defender or a backup-process ... disable all that is not necessary for the OS and for the installation.
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
- Highlight
- Email to a Friend
Thanks for the tips:
- turned off Virus Software
- turned of Firewall
- stopped all non-essential services
- installed .net 4 framework (already there since AIMS 2013 is installed)
It truely is the this MSI that is the issue.
BaseImageLibrary2013.msi
(C:\Autodesk\AutoCAD_Map_3D_2013_English_Win_32bi
I wonder if this MSI is corrupted on the install DVD/Download...
- Highlight
- Email to a Friend
ok, since the Low Rez MSI was the issue, I hacked the Setup.ini found in this folder:
C:\Autodesk\AutoCAD_Map_3D_2013_English_Win_32bit/
I found the [CMILB2013] section that refers to the Low Res Materials around line 303
Commented out everything with Pounds # beneath the [CMILB2013]
I copy and pasted the [CM2013] stuff because Map 3D 2013 won't install without the [CMILB2013]
which effectively installed the high-rez MaterialLibrary2013.msi twice
Ugly, but at least I got past the corrupted Low Rez Materials MSI.
