AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Instabilit y in Map 3D 2012 with Oracle FDO provider
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is anyone using this provider without issue? I kept getting random errors while editing features like:
- failed to save edit set
-feature source is disconnected
- failed to describe class
- item "layer name" not found in collection
- SchemaName: LayerName (304). Rev #<1>
In every instance I am absolutely connected to Oracle. Editing features typically works the first time I setup the drawing's connection. However after saving and reopening the drawing the issues sometimes, not always surface.
This works 100% stable in Map 3D 2010 but I unfortunately need the ENHANCED styling that Map 2012 provides.
My setup:
Windows 7 64bit
4gb ram
Oracle 11gR1 64bit client
Map 3d 2012 64bit
Re: Instabilit y in Map 3D 2012 with Oracle FDO provider
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, you are not alone. This occurs in 2013 (Map 3D and AIMS) too.
I have been testing Autodesk FDO for Oracle and SL-KING FDO for Oracle and found that the Autodesk FDO for Oracle has some significant instabilities, especially over 100 users. I've switched to SL-KING FDO but there are some limitations with Themeing etc.
The Autodesk FDO for Oracle definitely needs some tweaking, if not some serious re-work for both Autodesk Map 3D 2012 and 2013 as well as Autodesk Infrastructure Map Server 2012 and 2013.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
thank you Gordon.
I recently opened a ticket with Autodesk. They said my errors were linked to a change request that is fixed but not due out until their next patch which they have no date for.
They advised me that these issues are fixed in 2013 so I upgraded and have had good results so far. However my user group is only about 7 so I would probably not encounter some of the issues you are having.
