AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Inserting a Block With Attributab le Text
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello. I am inserting a block into my drawing that has attributable text, and when I insert and pick the insertion point, the block prompts me immediately to fill in attributable text fields. My problem is that it runs through the sequence twice. How can I edit the block so it only does it once?
Thank you.
Re: Inserting a Block With Attributab le Text
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What sequence runs twice? The insertion of the block or the insert-dialog for the insertion or the attribute request dialog or are you asked for the attributive contect twice in the command-line?
And "how did you start the insertion"? By entering _INSERT in the commandline or by starting the insertcommand from a toolbar or from the ribbon or from an application or from a self built tool/lisp/vba/menu/...?
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The attribute request dialog sequence runs twice. Actually, the prompt appears in the command line for filling in the information. A dialog box does not appear at all. I used Insert from the menu bar to insert the block into the drawing.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Maybe then that you have your attribute-definitions doubled in your block-definition?
What happens if you set the sysvar ATTDIA to 1 ==> you get then a dialog that asks you to fill in the attributes, are there any attribute-names double?
You can also try to double-click the block when your insertion and attribute-request-handling was finished. You should then get a dialog that shows your attributes. And if there are any attributes doubled then you see these in red-colored.
- alfred -
Alfred NESWADBA
