• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    Inserting a Block With Attributable Text
    138 Views, 3 Replies
    07-27-2012 10:45 AM
    Hello. I am inserting a block into my drawing that has attributable text, and when I insert and pick the insertion point, the block prompts me immediately to fill in attributable text fields. My problem is that it runs through the sequence twice. How can I edit the block so it only does it once?
    Thank you.
    Please use plain text.
    Re: Inserting a Block With Attributable Text
    07-27-2012 11:45 AM in reply to: jfranc6253
    What sequence runs twice? The insertion of the block or the insert-dialog for the insertion or the attribute request dialog or are you asked for the attributive contect twice in the command-line?
    And "how did you start the insertion"? By entering _INSERT in the commandline or by starting the insertcommand from a toolbar or from the ribbon or from an application or from a self built tool/lisp/vba/menu/...?
    - alfred -
    Alfred NESWADBA
    Member
    07-27-2012 11:50 AM in reply to: alfred.neswadba
    The attribute request dialog sequence runs twice. Actually, the prompt appears in the command line for filling in the information. A dialog box does not appear at all. I used Insert from the menu bar to insert the block into the drawing.
    07-27-2012 12:29 PM in reply to: jfranc6253
    Maybe then that you have your attribute-definitions doubled in your block-definition?
    What happens if you set the sysvar ATTDIA to 1 ==> you get then a dialog that asks you to fill in the attributes, are there any attribute-names double?
    You can also try to double-click the block when your insertion and attribute-request-handling was finished. You should then get a dialog that shows your attributes. And if there are any attributes doubled then you see these in red-colored.
    - alfred -
    Alfred NESWADBA
