• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Member
    estbe
    Accepted Solution
    Insert dialog box
    467 Views, 10 Replies
    09-07-2011 08:53 AM
    How do I bring up a dialog box with the insert command? after I type 'insert' it asks me in the command line what the name of the block is. I would like to bring up the dialog box so that I can browse to my block library etc.
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: Insert dialog box
    09-07-2011 12:14 PM in reply to: estbe
    Set FILEDIA=1
    Active Member
    estbe
    09-09-2011 07:57 AM in reply to: antoniovinci
    the filedia is already set to 1. any other ideas
    09-09-2011 08:15 AM in reply to: estbe
    Set CMDDIA to 1
    Mark Martinez
    DC CADD
    Mark Martinez
    DC CADD
    Active Member
    estbe
    09-09-2011 08:23 AM in reply to: MarkMartinez
    Yes, I tried that already. Does the AcFields support file have anything to do with the dialog boxes. My autocad session was having trouble finding certain support files.
    09-09-2011 08:27 AM in reply to: estbe
    If that's the case, a Repair/Reinstall from Control Panel is in order to get the files required on your system.
    Mark Martinez
    DC CADD
    Mark Martinez
    DC CADD
    Active Member
    estbe
    09-09-2011 08:29 AM in reply to: MarkMartinez
    how do you do that
    09-11-2011 03:58 PM in reply to: estbe
    Go to:
    START > Control Panel > Programs and Features > Right click  on your Autodesk Program and select "Unistall/Change". It will guide you thru the Repair process.
    AutoCAD Map 3D 2013
    Windows Vista Business
    Service Pack 2
    Intel(R) Core(tm2) Quad 3.0 GHz
    4.0 GB RAM
    Active Member
    estbe
    09-20-2011 06:03 AM in reply to: grimline
    Are there any other settings that control use of dialog boxes. Other commands: Hatch, Layer manager, Dimstyle also do not come up as a dialog box which I would like them to. My system administrator would like to avoid doing a repair, reinstall.
    *Expert Elite*
    Murph
    09-20-2011 04:27 PM in reply to: estbe
    Sounds like you have a bad install and/or the wrong dotnet frame work installed.
    Murph
    Supportting the troops daily.
