• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    Insert Blocks at Point Locations
    105 Views, 5 Replies
    07-06-2001 04:43 AM
    Does anyone have any ideas how to set up a query or some other mechanism to insert a plain, dumb block on each one of a set of points? Any help would be great,
    Des
    Please use plain text.
    Member
    Re: Insert Blocks at Point Locations
    07-06-2001 07:10 AM in reply to: dmryglod
    Consider Blocktools from www.dotsoft.com. It does what you're looking for. Verify your insert points though - sometimes the program has performed erratically for me.
    Distinguished Contributor
    Re:
    07-15-2001 10:13 PM in reply to: dmryglod
    Surely there is a way to do it in AutoCAD. I need this too, so I will repost the message. Thanks. Pat
    Member
    07-16-2001 02:27 AM in reply to: dmryglod
    Are you trying to do this during Import? If so there is way to do map points to blocks during import.
    Re:
    07-16-2001 10:41 PM in reply to: dmryglod
    Greetings,
    No, I have the points already loaded. What is the way to do points to blocks anyway since I can reload the points. I get the points in as shape files typically, but sometimes I use a program called EZYSURF.
    Member
    Re:
    07-17-2001 03:10 AM in reply to: dmryglod
    Patrick,
    Use the Point Mapping dialog. In the drawing that you are importing into, create Blocks the way you want them. This could include Block attributes and you will need to get the scale correct for the data you are importing. You can create tags with the field name from the incoming data if you want to place attribute tags on the Blocks as you import them. (The best way to do all this is to just import the points with the data you want, then zoom onto an area and create or scale an existing block so that it is correct. Check the data that came in so that you can get the tag right, etc... Then you can erase it all and start again.) Once in the Import Options dialog, for the Layer that contains the Points, choose the Points column. A '...' button will appear. This will take you to the Point Mapping dialog where you can specify how to import the points, choose a Block, get Block from data and add atttribute tags. The tricky part is getting the Blocks right, fun with AutoCAD, but once it is set up right it works great. Hope this helps, Good luck.
