• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Contributor
    Inputing Lat/Long points manually
    110 Views, 5 Replies
    06-28-2007 05:08 AM
    I have downloaded a county map that is set to NAD83 datum, Latitude-Longitude Degrees. I can track the coordinates using the Track Coordinates tool. I want to draw points where manholes are using Lat/Long coordinates given to me. Everytime I type in a Lat/Long point the point goes off the map and when I put the tracker on it, it is not what I typed.
    How to I put my manholes on this map using Lat/Long points?
    I typed the info correctly so I must have a setting wrong that I don't know about.
    Please use plain text.
    *Tripp Corbin, GISP
    Re: Inputing Lat/Long points manually
    06-28-2007 05:15 AM in reply to: wrightsville1
    If I am not mistaken, you must convert Degrees Minutes and Seconds to
    Decimal Degrees in order to input those positions. CorpsCon from the Corps
    of Engineers is a great tool for this and it is free. Here is the link:
    http://crunch.tec.army.mil/software/corpscon/corpscon.html
    Tripp Corbin, MCP, CFM, GISP
    Associate Vice President, GIS/Mapping
    ESRI Authorized Instructor
    Keck & Wood, Inc.
    www.keckwood.com
    (678) 417-4013
    (678) 417-8785 fax
    Keck & Wood, Inc offers instructor led and virtual training for ESRI's
    ArcGIS & ArcView software.
    Please visit www.keckwood.com for more information including a schedule of
    upcoming classes.
    wrote in message news:5641359@discussion.autodesk.com...
    about.
    *James Murphy
    06-28-2007 07:33 AM in reply to: wrightsville1
    Have you tried using the digitize from the Coordinate Tracker?
    Murph
    The world is not FLAT so why is your GIS data?
    http://map3d.wordpress.com
    about.
    Valued Contributor
    06-28-2007 08:07 AM in reply to: wrightsville1
    Thanks for the link Tripp!
    I'll just convert the Lat/Long Manhole points and put them on the State Planes map.
    Distinguished Contributor
    06-28-2007 12:00 PM in reply to: wrightsville1
    FYI
    We used to use the Corpscon but now use a program that is free for small use. You can convert txt to dxf shp Google earth and a whole lot more.
    http://www.gpsu.co.uk/
    Valued Contributor
    06-29-2007 04:59 AM in reply to: wrightsville1
    jessebelcher-tvec
    Thanks for the link. I will definitely check it out!
