• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    Accepted Solution
    Industry model in SQL server 2012 error
    219 Views, 2 Replies
    04-09-2012 01:34 AM
    I have problem with deploying IM to SQL server 2012 Expres. Everithings runs OK, but when I try to update industry model schema (water, waste water, ...) I got this error:
    Structure update problem occurred during update.
    Message:
    Adding the feature class 'Contact' failed.
    Specific Error:
    NEXT VALUE FOR function cannot be used within CASE, CHOOSE, COALESCE, IIF, ISNULL and NULLIF.
    Plug-in: Water Data Model (2.5.0)
    1 Structureupdateplugin(s) failed.
    Same error (NEXT VALUE FOR ...) appears when i try to manually create new feature class in administrator.
    Any ideas how to solve this ?
    ACAD version: Map 2013 + SQL Server FDO Hotfix.
    Please use plain text.
    Employee
    weibelt
    Re: Industry model in SQL server 2012 error
    04-10-2012 01:07 AM in reply to: DavidPavlicek
    Hi
    Please have a look to http://usa.autodesk.com/autocad-map-3d/system-requirements/. Only SQL Sever 2008 R2 is supported.
    Best regards
    Tobias
    Member
    04-10-2012 01:17 AM in reply to: DavidPavlicek
    Oh, thanks i overlooked this.
