• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Contributor
    Incorrect ECW coordinates
    175 Views, 1 Replies
    09-04-2012 12:42 PM
    I've created same topic in Civil 3D, but I think here I'll an answer faster.
    I have GeoPDF that I can't attach properly to drawing in Civil 3D.
    So with Global Mapper I exported it to geo-referenced ECW.
    I checked ECW in Global Mapper and ArcMap, everything just fine.
    However when I did mapiinsert in Civil 3D, image appeared with shifted coordinates.
    The original coordinate system of PDF and ECW is BC/Albers and coordinate grid is Lat/ Longs.
    I've uploaded ECW, if somebody could try it.
    https://docs.google.com/open?id=0B5LTHGXLBfyscnpfUHlEYm1tczQ
    This is a picture from Civil 3D with Lat Long grid above the image.
    Thanks.
    Please use plain text.
    antoniovinci
    Re: Incorrect ECW coordinates
    09-05-2012 03:39 AM in reply to: Vasily_BC
    In my Map2006 CRS list, there is no BC Albers, so I created it by scratch basing on EPSG:3005 parameters (command _ADEDEFCRDSYS).
    If I load your .ECW in this brand new CRS, and I draw a draft yellow line on the West coast, it fits exactly on Google Earth - check my .ZIP one, unpacking the content in the .ECW folder.
    Now you should try to attach my DWG into a LL84 empty drawing (EPSG:4326) by means of _ADEDRAWINGS, then perform a draw query to check the conversion.
