• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    d.kerkhoff
    Importing text, blocks and attributes are too big
    482 Views, 4 Replies
    02-06-2012 11:34 PM
    I'll try to import a text file with a string: pointnumber, easting, northing, elevation, discription, but I get very big blocks and attributes in my drawing. I use Autocad 2011 Map 3D, on a windows XP OS. I'll importing the text string with the import command. Easting and Northing are for the position. The Elevation, pointnumber and discription are attributes from a block. I can only choose a block: "Map_Survey_point" This is the only block I can choose. When I import the text, the scale from the importing blocks are too big. How can I change the size of the block and attributes? Anybode an idea?
    Please use plain text.
    Murph
    Re: Importing text, blocks and attributes are too big
    02-07-2012 04:19 AM in reply to: d.kerkhoff
    You can use Quick Select "qselect" after you import the points then change the  scale in the property palette. I have no idea why the default is so large or why they scale up.
    Murph
    Supportting the troops daily.
    Member
    d.kerkhoff
    02-07-2012 11:51 PM in reply to: Murph
    Murph.
    Thanks for your help. That is the solution. It works! Thank you very much.
    Duncan
    Murph
    02-08-2012 04:26 AM in reply to: d.kerkhoff
    d.kerkhoff wrote:
    Murph.
    Duncan
    You are welcome. :smileyhappy:
    Murph
    Valued Contributor
    03-14-2012 12:02 PM in reply to: d.kerkhoff
    Hi mr kerkhoff,
    I am new to autocad map....can you please show me how you imported text in your map ...I am having great difficulty i doing this.thanks
