• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    65Pan
    Importing .jp2 Files
    439 Views, 2 Replies
    08-24-2012 08:56 AM
    Does anyone know of a patch for AutoCAD Map 2013 which allows importing .jp2 files. We had version 2011 setup as such, but having difficulty setting up 2013. Thanks
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: Importing .jp2 Files
    08-24-2012 09:38 AM in reply to: 65Pan
    You don't need that at all: with Irfanview, you can convert your files from Jpeg2000 format to "classic" .JPG, sir.
    If the .JP2 ones have an associated worldfile, the derivated .JPGs will use it automatically.
    New Member
    10-02-2012 08:26 AM in reply to: 65Pan
    That will work fine if the files are yours to modify.
    If they are in a secured location you're out of luck.
    Autodesk should add the extension to it's list of supported files.
    I'm Using Map 2012 so it may be there in 2013, - I don't and won't know until our IT Dept. installs it.
