• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    *Dupuis, Lorraine
    Importing UTM coordinates
    202 Views, 2 Replies
    11-19-2002 11:37 PM
    Can anyone suggest a reasonably priced software that can import survey
    points and plot blocks with attributes....I have tried Pointor and it seems
    to work relatively well. I am just wondering if there is anything elso out
    there?
    Please use plain text.
    Re: Importing UTM coordinates
    11-20-2002 07:04 AM in reply to: *Dupuis, Lorraine
    If you are simply seeking the data from each block, Excellink may work for you. I am of course assuming you are not using Autocad Map which would do it for you.
    *Ivan
    Map 6 and Oracle 9i (client configuration)
    11-21-2002 03:18 AM in reply to: *Dupuis, Lorraine
    Hi everyone,
    I installed Oracle 9i (release 1), oracle client 9i, and acadmap 6, too. But
    acadmap 6 doesn't work the oracle command, do you know if there any idea
    about the configuration of the oracle client to connect fine?
    I appreciate the answering,
    Ivan
