• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    teresaneal
    Imported 3D polylines will not change to layer style line types.
    273 Views, 8 Replies
    05-14-2012 01:39 PM
    When I import shape files the polylines will not take the layer style I move them to. They stay a continuous linetype. Linetype and Lineweight is set to ByLayer. Only difference between the new lines and the lines drawing correctly is the lines that stay continuous are 3D polylines and the correct ones are normal polylines. Can anyone tell me what I need to do to make the imported lines accept my layer linetypes?
    Please use plain text.
    *Expert Elite*
    Murph
    Re: Imported 3D polylines will not change to layer style line types.
    05-14-2012 02:42 PM in reply to: teresaneal
    3D polylines will only display as a continuous line, been that way since 3D polylines were created in AutoCAD.
    Murph
    Supportting the troops daily.
    *Expert Elite*
    antoniovinci
    05-15-2012 04:51 AM in reply to: Murph
    teresaneal wrote
    WhenI import shape files ... lines that stay continuous are 3D polylines
    Shapefiles do NOT contain 3D polylines, so please check the nature of them by means of _LIST command.
    Maybe it's only a _LTSCALE issue, lady.
    *Expert Elite*
    Murph
    05-15-2012 05:06 AM in reply to: antoniovinci
    Yes they do.
     :smileyhappy:
    Murph
    *Expert Elite*
    antoniovinci
    05-15-2012 09:55 AM in reply to: Murph
    Dear Murph,
    a polyline with an elevation along the Z axis is NOT a 3D poly, but only a simple, poor, humble 2D contour...
    Member
    teresaneal
    05-15-2012 12:10 PM in reply to: antoniovinci
    Thanks, to everyone or your help! Teresa
    *Expert Elite*
    Murph
    05-15-2012 03:06 PM in reply to: antoniovinci
    antoniovinci wrote:
    Dear Murph,
    In Autocad yes, I agree but in ESRI you can create 3d polylines as long as you have the 3D analyzes module
    Murph
    *Expert Elite*
    antoniovinci
    05-17-2012 04:01 AM in reply to: Murph
    I don't believe that ESRI is able to generate 3D shapes: would you upload one of these miracles..? Thanx!
    *Expert Elite*
    Murph
    05-17-2012 04:24 AM in reply to: antoniovinci
    Would if I still had the ESRI software, my student versions expired.
    Murph
