• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Map 3D
    Distinguished Contributor
    Image .ecw
    803 Views, 6 Replies
    03-22-2012 10:11 AM
    I have read in an image .ecw with "Map> insert" and also "Data Connect".
    However MAP misplaced the image even though the coordinate is in the file ewwx is correct.
    It is correctly positioned with ArcGIS.
    Why ArcGIS does right but the MAP fails?
    Can anyone find the error in the screenshot?
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: Image .ecw
    03-22-2012 01:52 PM in reply to: teflon
    Try this: with Notepad, change from comma to point:
    0.060367790095918798
    -0.19047493008779257
    -0.19041557728784345
    -0.060162200272977327
    762907.22959315591
    7460838.1234895689
    Re: Image .ecw
    03-22-2012 04:36 PM in reply to: teflon
    Thanks!
    Already done that! But it does not work!
    There are three files:
    .ewwx
    .xml
    .ecw (the image)
    I changed the commas in .ewwx to points but no success!
    I even tried and removed other files away but it still insert the image at wrong coordinates.
    Valued Contributor
    ro_fr
    Re: Image .ecw
    03-22-2012 11:38 PM in reply to: teflon
    when you check the coordinate settings in the "insertion" tab in the "Image Correlation" dialog bôx - are the different from the ones displayed in the "Source" tab?
    If so, change the drawing units to Meter and see if that helps (command: _units -afaik).
    Rob
    *Expert Elite*
    antoniovinci
    Re: Image .ecw
    03-23-2012 12:21 AM in reply to: teflon
    Maybe Autocad is able to read the embedded header of your georeferenced image, so try to copy ONLY the .ECW to a new folder (without worldfile or other stuff) and _MAPIINSERT it: any changes?
    Re: Image .ecw
    03-26-2012 03:56 PM in reply to: teflon
    The images are going to work when you do a FDO connection or use ArcGIS because those methods will reproject or transform the image to match the current coordinate system. The MAPIINSERT command will not transform the imagery on the fly. You would need Raster Design to do what you are asking and the command would be IINSERT. There are two ways of doing what you need to do.
    1. Find out the coordinate system of the imagery. Make a new drawing with the coordinate system of the imagery and MAPIINSERT the imagery. Save. Open the drawing you want to insert the imagery into, attach the drawing and do a query from the drawing with the imagery.
    2. Create a shapefile with the imagery boundary while using arcgis. Import the shapefile into your drawing and manually pick the points of of entry, scale and rotate.
    Hope that helps.
    Valued Mentor
    LisaPohlmeyer
    Re: Image .ecw
    03-28-2012 06:32 AM in reply to: teflon
    This is why I'm estatic that Raster Design is now included with IDS 2013!
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
