AutoCAD Map 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Hyperlinks
- Highlight
- Email to a Friend
- Report Inappropriate Content
I want to insert hyperlinks to a file I have.
I use the command 'hyperlink' I select the object and the program crashes and is 'not responding'
Now the tricky is that this happens both in Autocad Map 2010 and 2013. And happens also in files I already have hyperlinks and new ones. If I run the software as an administrator in my pc, the command works excellent.
I insert hyperlinks in the files for many years and till now everything worked fine.
What could be wrong?
Re: Hyperlinks
- Highlight
- Email to a Friend
Since "admin" has no problems, that's a clear Windows user rights issue...
Call your IT guru, he'll fix it in 2 minutes, sir.
By the way: are you using Win7 as operating system?
Re: Hyperlinks
- Highlight
- Email to a Friend
Thanks for your response :-)
The PC has windows vista business.
For me the weird is that that both Autocad Map 2010 and 2013 'not respond' when I use the hyperlink command.
The configuration of the PC hasn't changed. We have only installed Google Earth Pro version 6.2.2.6613
