• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    Accepted Solution
    How to set symbols in AutoDesk Map 3D 2012 whenever using oracle 10g as DB
    332 Views, 4 Replies
    08-01-2012 02:11 AM
    I have created a template file but whenever I open and display data in AutoCAD Map 3D 2012 it does not apply to the opened data from Oracle 10g. Infact, it change every time I open the data from database!
    Please help if any body of you using the symbol in AutoDesk Map 3D 2012. Also note that my database is Oracle 10g.
    Anand
    Please use plain text.
    *Expert Elite*
    Murph
    Re: How to set symbols in AutoDesk Map 3D 2012 whenever using oracle 10g as DB
    08-02-2012 04:05 AM in reply to: TATA_JUNE2007
    Once you style the data you need to save that connection as a .layer file then connect to that layer file. Right click on the connnected data layer in the display manager.
    Murph
    Supportting the troops daily.
    Active Contributor
    Re: How to set symbols in AutoDesk Map 3D 2012 whenever using oracle 10g as DB.
    08-02-2012 05:02 AM in reply to: Murph
    Thank you very much Murph,
    I have save the connection layer as .layer but again when I open the data then its display with different style. Any thing else i need to look into that..
    Anand
    *Expert Elite*
    Murph
    08-03-2012 03:29 PM in reply to: TATA_JUNE2007
    Are you connecting to the .layer file or making a new connection to the Oracle DB?
    Murph
    Active Contributor
    08-27-2012 12:49 AM in reply to: Murph
    Thanks mate, it all works now.
    Anand
