• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    How do I break linked polygons created from New Feature from Geometry?
    120 Views, 3 Replies
    02-06-2013 11:53 AM
    Hello, I'm using AutoCAD Map 3D. I had some geometry that I needed to convert into a shape file, so I selected on the shp layer "New Feature from Geometry".  Everything converted to join the shape layer, but now it is all connected.  I want to move/edit individual polygons but when I go to select one it selects all of them.
    I've noticed I can "create new feature" one at a time, but I'd really like to find how to unlink them after I've converted them in bulk.
    Please use plain text.
    Murph
    Re: How do I break linked polygons created from New Feature from Geometry?
    02-06-2013 02:51 PM in reply to: Jfactory
    New feature from geometery is designed to work one feature at a time. That allows you to add/edit the feature atrributes. To "bulk convert" you need to use the map export command.
    Murph
    Supportting the troops daily.
    02-07-2013 02:57 PM in reply to: Murph
    Thank you, Murph!
    Murph
    02-07-2013 03:08 PM in reply to: Jfactory
    Jfactory wrote:
    Thank you, Murph!
    You're welcomed.
    Murph
