AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
How can ı save complex styles for line features?H elpppppppp pppppppp
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi everyone,
I have to create complex styles for line features. This features like different road types and stream type. When ı create my own style like on capture, ı want to import feature styles to other projects.
Please help about this subject.
In arcgis ı can get largely spread style library for polygon, line or point.
And ı can modify and resave this feature style.
But in Autocad map 3d it s very diffucult.
Please helppppppppppppppppppppppp
Re: How can ı save complex styles for line features?H elpppppppp pppppppp
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think you will find some answers in the following article:
Kind regards,
Sébastien Baudin
Autodesk Support Team
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you want to use your line styles or other symbols, you can first save your GIS layer as "layer" file right clicking on the GIS layer. And after it, you can import this "layer" file in other projects.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
one way.. create a .layer with one item styled as you like , ie a section of road line styled. Copy that file and paste the .layer file in windows explorer and change the name of the copy to preserve your orignal for another use., then drag & drop that into a map. Right click the layer in Display manager and create a new object. the new object will acquire the style. or if you have dwg objects select create new feature from geometry , select the objects and they will acquire the styling. You could map import a sdf or shp and qselect and add it to the style layer this way. erase the object you dropped into the map to remove it from the data set and check in.
dave
