AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Help Loading 3D Modeling Workspace in Map3D
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Curious as to how to load the 3D Modeling workspace so that I can access the editing features and whatnot without having to type in the commands. I have seen a few different questions dealing with this issue, they pretty much said to into the "custom user interface", click on the transer tab and then path to the support folder where you would load the "acad.cuix" file and drag the 3D Modeling Workspace over to the left hand side. The issue I'm having is that when I path to the folder with all the different ".cuix" files there isn't a plain "acad.cuix" file to be found and none of the other options offer any sort of 3D Modeling Workspace?
Re: Help Loading 3D Modeling Workspace in Map3D
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm having this same issue. As a workaround, I've created a new workspace '3D Modeling' and in the 'Customize' section I am transferring Ribbon tabs over from 'All Customization Files' to my new one. I'm selecting the ones that seem to fit best; i.e. Home - 3D Basics, Mesh, Surface Modeling, etc.
It would be MUCH easier if there was a cuix file I could load. But it doesn't seem that way for AutoCAD Map 3D 2013.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello
I think taht an other solution would be to get (and use) CUIX files comming from a standard AutoCAD ...
Bye, Pat
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Well from finding other threads about this issue; this blog is helpful geoExpressions blog
However, ACAD Map 2013 is different than 2010. .cuix files can be found in C:\Program Files\Autodesk\AutoCAD Map 2013\UserDataCache\en-us\Support
Also there seems to be some files, including the default file (which is probably why I couldn't find the other ones till now) located here:
C:\Users\johnsmith\AppData\Roaming\Autodesk\AutoCA
Anyway, I know this reply is most likely too late to help OP but I thought I'd post what could be an update to the other threads that talk about the blog.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Okay the most helpful thing I've found is from docs.autodesk.com/MAP/2012/ENU/readme-map.html
Running AutoCAD Map 3D as AutoCAD
You can use the MENU command to run AutoCAD Map 3D as AutoCAD.
To Run AutoCAD Map 3D as AutoCAD:
1. At the Command line, enter MENU.
2. In the Select Customization File dialog box, select acad.CUIX.
Using the CUI command or the 'Workspace Settings' has been a pain. This Menu thing is easy.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
One last thing. Sorry for all the posts but it's been frustrating for me figuring out how to customize stuff then I messed it up so I would like to help anyone else if someday they'll be looking for a similar solution.
The two locations I mentioned before each have a Map.cuix. So if you mess up one, just copy it over to the other spot.
CUILOAD is great as is MENU.
