• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Contributor
    Accepted Solution
    Hatch lines weight
    184 Views, 3 Replies
    01-30-2013 01:00 PM
    Is there a way to control weight of line for hatch?
    I'm trying to make some style for number of areas and when I do hatch on a paper it's almost invisible because it's weight!
    Tons of hatch patterns and they all useless!?
    Thanks for any suggestions.
    Please use plain text.
    Valued Mentor
    Re: Hatch lines weight
    01-30-2013 01:27 PM in reply to: Vasily_BC
    Drawing objects or data connected; shp, sdf, etc?
    lw is accessible in properties or in the layer properties manager.  There is a button to turn lw off and on on dispaly also.
    FDO objects in styles
    look in help search for plotting lineweights
    dave
    Valued Contributor
    01-30-2013 01:58 PM in reply to: parkr4st
    Data connect. Shapefile, layer or sdf.
    Valued Contributor
    ro_fr
    01-30-2013 11:09 PM in reply to: Vasily_BC
    Hi Vasily,
    for FDO features you can apply a lineweight for hatches but not using Display Manager's Style Editor. You need to add it manually to your .layer file.
    For a simple hatch (Dash) you need to add the <LineWeight> tag:
    <Name>DASH</Name>
     <Graphics>
      <Path>
       <Geometry>M 0.0,0.0 h 0.125 M 0.125,0.125 h 0.125</Geometry>
        <LineColor>%HATCHCOLOR%</LineColor>
        <LineWeight>0.1</LineWeight>
    save the layer file (context menu).
    Open in XML/text Editor
    Add <lineweight> tag for hatch definition
    save
    load layer into map again.
    Good luck,
    Rob
