• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    KrakowiAneczka
    Google Earth extension
    1333 Views, 6 Replies
    05-16-2012 02:48 AM
    Hello again!
    What happened with Google Earth extension?
    I cannot find it in labs. I've instaleed Map2012 on new laptop and I'm sure I had Google Earth plug in on the old one.
    Can anyone help with where do I find GE for Map 2012?
    Thanks a lot for help!!
    Ania
    Please use plain text.
    Distinguished Mentor
    thepworth
    Re: Google Earth extension
    05-16-2012 09:57 AM in reply to: KrakowiAneczka
    check out the discussion on GE in the Civil3D forumn - probably explains it better, but Google and AD appear to be parting ways...  AD may be too far in with Microsoft and transferring over to Bing Maps as an alternate... But the Bing plug in is only good through June 30, so....
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    *Expert Elite*
    antoniovinci
    05-17-2012 04:14 AM in reply to: thepworth
    Moreover, the Basejump Project supports only 2013 releases, so Ania's one is out.
    An alternative solution (working in my Map2006) is to load the Bing imagery in a free Gis as Openlayers resource, then exporting the pair TIF+TFW, which will be _MAPIINSERTed in Autocad.
    Active Contributor
    KrakowiAneczka
    05-18-2012 06:40 AM in reply to: KrakowiAneczka
    Thank you guys :smileyhappy:
    but you lost me with that AD :smileywink:
    All i need to do is to export dwg to GE :smileyhappy:
    I have map2013 but i find it rubbish so far :/
    *Expert Elite*
    antoniovinci
    05-18-2012 08:08 AM in reply to: KrakowiAneczka
    AD = AutoDesk
    Kochana, if you only wanna export DWG objects to GE, simply _MAPEXPORT them to shape LL84, then look for a tool like SHP2KML to get all in Google Earth format...
    thepworth
    05-18-2012 08:11 AM in reply to: antoniovinci
    for example, check out:
    http://www.sl-king.com/ for a KML FDO Provider...
    C3D 2011
    Active Contributor
    KrakowiAneczka
    05-18-2012 08:12 AM in reply to: KrakowiAneczka
    hehe, nice....thanks a lot!
