• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Accepted Solution
    Georeferenced Images
    1082 Views, 9 Replies
    01-30-2012 11:14 AM
    I have some aerial images inserted in Map 2012 (Win 7 64-bit, Infrastructure Suite 2012 Premium). I need to send these to someone using ArcMap (not sure of version). I tried just eTransmitting the dwg to them and that did not work. What is the best way to send this to them so that the images will hold the georeference?
    Please use plain text.
    Active Member
    Re: Georeferenced Images
    01-30-2012 12:57 PM in reply to: rferguson7
    What file type is the air photo?
    Distinguished Mentor
    thepworth
    01-30-2012 01:55 PM in reply to: rferguson7
    if you use the old "mapiinsert" for Map Image Insert command, then they'll come through.  FDO does not xref....
    you'll have to use mapiinsert to get the images into a drawing in their native coordinates and then attach/drawing query to transform the coordinate system into your working CS -
    not too bad, but not as easy as we'd like....
    TdH
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    01-30-2012 02:05 PM in reply to: thepworth
    Thanks for your responses!
    They are jpeg's that were inserted as images via Civil 3D 2012. I spent A LOT (several days...we are talking several jpegs per drawing and about a dozen drawings) of time scaling, rotating, and translating them into the correct position using NAD83 coordinate system. I now have been told that the images need to be georeferenced and used in ArcMap. When I opened the file I made in Map, and go to MAPIINSERT the photos again using the existing photos as a guide, it then shows in the Image Management that they are there twice. Does this not mean that the original images are ok? I am just wondering if I go thru all the trouble to re-insert them all using MAPIINSERT will it even make a difference or is it simply the way I am transmitting the file to them or something they may be doing incorrectly on their end???
    thepworth
    01-30-2012 02:08 PM in reply to: rferguson7
    if they're in the same place, then the problem looks like it's at the other end (ARC).  not having arc here, can't be of much further help.  C3D/Map3D doesn't write out world files for use w/o having "Raster Design" running on top :smileysad:
    Sorry to be the bearer of bad news... unless someone can point me out as wrong - which i'd be happy to admit my (near) ignorance :smileywink:
    TdH
    C3D 2011
    01-30-2012 02:38 PM in reply to: thepworth
    Ok, so just to be extra sure this is not me, the proper procedure to give this to them would be:
    1. MAPIINSERT the jpeg and make same location, scale, and rotation adjustments as before,
    2. Save
    3. eTransmit the file to a zip file and email to them.
    Is this correct? Sorry, I know this has been discussed but I want to just be certain that the problem is not on my end and confirm that eTransmit is the way to go. Thanks again.
    *Expert Elite*
    Murph
    01-30-2012 02:53 PM in reply to: rferguson7
    Are they running AutoCAD with the ESRI ArcMap extension? If they are not opening the dwgs in AutoCAD then the image referances may not be of any use to them. If the images are georeferanced and have the world file with them they can use the dwg as is and then insert the images in ESRI ArcView.
    Murph
    Supportting the troops daily.
    thepworth
    01-30-2012 03:01 PM in reply to: rferguson7
    Lemme back you off a step or two.  Mapiinsert is more oriented towards inserting georeferenced images into the images' native coordinate system, such as from a .PRJ projection file & .TFW Tiff world file that collectively state the coordinate system of the image & reference a given location (i.e. center of top left pixel & pixel dimension in x/y values & x/y scales).  great if you just want to bring in an orthophoto background.  if you're bringing in an image and using rotate/scale/align to "rubbersheet" it to match your drawing, then all of the work/processing from mapiinsert will be discarded.  so you don't want to mix the two.  however, if you have Raster Design, then you could take a image (such as an as-built scan from construction drawings) & rotate/stretch/align to match a vector drawing and then push out a .TFW & .PRJ for that drawing to be used with other software that understands georeferencing (i.e. Arc).  don't mean to confuse you, but what is the imagery your'e wanting to transmit?  let's start there...
    C3D 2011
    *Expert Elite*
    antoniovinci
    01-30-2012 11:31 PM in reply to: thepworth
    Be happy, sir.
    You can definetely create a Worldfile with this free tool.
    Moreover I would import that pair JPG+JGW in the opensource Quantum Gis, in order to generate a full georeferenced  true Geotiff.
    01-31-2012 02:38 PM in reply to: antoniovinci
    THANK YOU antoniovinci  !!!!!
    That worked perfectly to output a jpw that is nice compact and emailable. Exactly what I was looking for. Cheers! :smileyhappy:
