AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Geomarker and Zoom Extents Screwed up
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Having some issues with my Map 3D project. When I used to work with this file the Geomarker was right in the center of my map project when I did a top view it showed the full extents. I had an AutoCAD Crash and now the geomarker is far out and now when I do a top view of the project it zooms out to an infinite distance. Is there a setting in AutoCAD that fixes this because I've had this happen before but I can't figure out how to fix this. Thanks.
Re: Geomarker and Zoom Extents Screwed up
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
what caused the crash? what is "far out"? Does Ctrl A highlight anything in the far outer fringes of the infinite distance?
What version of Map?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The crash was caused by a Fatal Error on my AutoCAD Map 3D 2010 program, which I reinstalled. The extents should normally be 1:50,000 for this project but now the far out extents is 8.45 X 10 to the power of 20. Doing the Ctrl A function didn't show anything outside the extents. Could this be a setting that is causing the project to use a world perspective for the zoom, rather than the local extents?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Set GEOMARKERVISIBILITY=0, save all, restart computer, reopen the drawing, set GEOMARKERVISIBILITY=1, zoom extents: any changes?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Doesn't fix the issue.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Seems to be GEOGRAPHICLOCATION is causing the issue, but when I'm trying to change it to my correct settings, it's not working and reverts back to the incorrect setting.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Have you checked the coordinate systems of your drawing and all of your connections? Are they all intact and correct still?
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
Being Civil Facebook
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I checked the map coordinate system as well as the coordinate system assigned to the Data and they are all assigned the correct coordinate system of UTM NAD83 Zone 14 Meter. I also checked to see if there was any data that was outside causing the zoomed out projection of 10 to the power of 20 and there is nothing. Any other suggestions?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Unfortunately it sounds like the drawing became corrupted, possibly due to the crash that was suffered. Just to be clear, this isn't effecting any other drawings, is it?
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The other drawings aren't affected by this. Will rebuild file. Thanks.
