• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Moderator
    Re: GeoTIF Greyed Out in Layout
    01-15-2013 03:40 AM in reply to: BrianHailey
    The problem can be solved by this way. You could change a color that is transparent (use a lightest color).
    Besides you could insert a JPG-image as a background.
    Please use plain text.
    *Expert Elite*
    01-15-2013 04:10 AM in reply to: Olga_Shevchenko
    good workaround! Is there any description why this depends from a coordinate-system set or not set?
    Another question: What can you do when you have to reference that object using FDO? There you can see the "transparency color" as option in the property window, but you can't change it.
    [EDIT] found the setting within MAPWSPACE ==> FDO-Stylization [/EDIT]
    But thank you for that workaround!
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Moderator
    01-15-2013 06:33 AM in reply to: alfred.neswadba
    it seems to me, that it doesn't depend upon CSS, rather upon GeoTiff. Look for the alpha channel, BlackColor  is transparent.
    If FDO connection is used one needs both images to be pre-loaded, JPG is to be used as a background for GeoTiff
    Look here, please
    Moderator
    01-15-2013 08:10 AM in reply to: BrianHailey
    Hi :smileyhappy:
    If FDO connection is used, you need to change Trancparency Color here. )))
    *Expert Elite*
    BrianHailey
    01-15-2013 04:09 PM in reply to: Olga_Shevchenko
    That seems to do the trick. Thanks!
    I'm just glad that I only have six images to do this to and not 30 or 40. :smileyhappy:
    Moderator
    01-15-2013 09:36 PM in reply to: BrianHailey
    BrianHailey написано:
    You are welcome :smileyhappy:
    I'm agree with you, this is a very exciting activity... :smileylol:
    Try to use _matchprop or use the FDO and combine all images into one layer
    PS Don't use _MAPCSASSIGN (  don't set the drawing coordinate system to WY83-EF) while GeoTIFF is opened by FDO Connection and before this
    Moderator
    01-16-2013 04:40 AM in reply to: BrianHailey
    This is another way, but it does not work sometimes.
