• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Member
    Generic CADD
    1529 Views, 19 Replies
    11-12-2009 01:20 PM
    I have an old Generic CADD .gcd file. Unfortunately the original software is on floppy disks and I don't have an "A drive" so I can't load the program and convert the files to a .dxf. Is there any utility out there that can convert a .gcd file to .dwg?
    Please use plain text.
    *neilw
    Re: Generic CADD
    11-12-2009 02:37 PM in reply to: robertm
    Generic Cad eventaully became Visual Cad (Numera Software). Visual Cad is
    able to open GCD files but I don't know if you can find it anywhere either.
    Try searching on those clues.
    *Ric Norris
    Re: Generic CADD
    11-13-2009 03:44 AM in reply to: robertm
    Hello Robert,
    Reply to me directly with your email address and I will forward you a
    conversion utility that was included with I think, AutoCAD LT v2. Converts
    .gcd files to AutoCAD R12 .dwg
    It runs through a DOS window & works very well under the circumstances.
    Cheers.
    Ric Norris.
    wrote in message news:6288222@discussion.autodesk.com...
    Active Member
    Re: Generic CADD
    11-13-2009 05:40 AM in reply to: robertm
    robertm@eapdd.com
    New Member
    Re: Generic CADD
    11-13-2009 08:42 AM in reply to: robertm
    Hello Ric,
    I've been looking for such a converter for some time now, can you send it to me as well?
    snakeman@home.se
    Dave
    Active Member
    Re: Generic CADD
    11-14-2009 09:47 AM in reply to: robertm
    Downloaded a trial copy of Visual Cad; was able to open the gcd file and save it as a dwg. It looks pretty funky, and a fair amount of work is required to clean it up and adjust it so it can work in ACMv2010, but it's one option that beats re-drawing. Thanks for the tip.
    Robert
    *neilw
    Re: Generic CADD
    11-14-2009 08:01 PM in reply to: robertm
    Sorry to hear it is not a good translation. I never had to go that route as
    I left the company and never had to translate the files to DWG.
    By the way, Corel owned Visual CAD for a time, in case that helps in some
    way.
    __________ Information from ESET NOD32 Antivirus, version of virus signature database 4608 (20091114) __________
    The message was checked by ESET NOD32 Antivirus.
    http://www.eset.com
    New Member
    Re: Generic CADD
    02-12-2010 08:30 AM in reply to: robertm
    I too have been searching for this tool for quite a while.... If it isn't too much trouble I would really appreciate a copy of the conversion utility.
    eric_campbell@cleanair.com
    Thanks in advance!
    New Member
    phons
    Re: Generic CADD
    03-06-2011 02:01 AM in reply to: robertm
    I have been using Generic Cadd 3.0 in about 1989. It has this wonderfull feater of loading a txt file.
    I still have the program and have it running on an old Dos system. But I cannot find the user instruction manual.
    I would be very happy if some-one could either sent me een a copy of the entire manual, or could tell me the instruction of importing the txt file in the program.
    Thank you very much.
    Phons
    New Member
    HCasey
    Re: Generic CADD
    03-11-2011 12:38 PM in reply to: phons
    I would like a copy of the convertor file to turn GCD files into DXF files.
    Thanks.
    Helen Casey
