AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Generating links - not understand ing
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So, first off, let me say I am brand new to this. I have been getting crash lessons from the net, reading my books and today from a gentleman that does this sort of stuff all the time. He came by to show me how to import a database and link the objects in my dwg to the database. He did a great job and I tried to follow along to his rapid fire clicking and choosing. But, I was not able to take notes along the way. So when he left, after my 10 min. lesson, I attempted to re-create the steps he took and I have hit a brick wall.
I opened my dwg, did a map import of my shp files. In the task plane, I attached my db file. I then created a link template and chose the proper column with the unique identification number. Now, (I THINK) I am supposed to "generate links". I go through that process and it says 0 files linked. I know I am forgetting something he did just before this point. My map just shows closed polygons, with no text. Most things I have found say you have to link text inside the polygons to the records. He did NOT do that. I am not sure what he did however.
When he was finished with our sample map, you could click on a line in table and it would zoom to the polygon on the map. My attempt does not do this. Help please!!!
Steve
Re: Generating links - not understand ing
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Does your polygons have Object Data attached to them that has one field that matches one field in the database table? Did you create the OD when you imported it?
Supportting the troops daily.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I do have object data attached and my unique number that I am trying to link form the DB file is in the object data.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
philsla wrote:I do have object data attached
Before "generating links", your guru typed in _MAPOD2ASE in order to convert those embedded Object Data to Database Links, sir.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could very well be. I will give that a try. Then, I generate the links?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ain't no Autocad at home, so I can't remember if _MAPOD2ASE just creates links instead of _ADEGENLINK, but I think so.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Those commands were not recognized. I failed to mention I was using an old version of Map, 2007
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
