• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    Gas line sliding mile classification
    156 Views, 2 Replies
    05-29-2012 06:17 AM
    Is anyone else working on gas transmission classification using the "sliding mile" for the building count?  If so what procedure are you using.  At this point I have run the 660' buffer around the lines added the address/structure point queried to within the buffer polygon then select all the points along a mile of point to get a count.  Tedious but working so far.  I just wonder if there is a better way.
    Please use plain text.
    Valued Mentor
    Re: Gas line sliding mile classification
    05-29-2012 06:52 AM in reply to: deetersmith
    it showed up earlier here
    http://forums.autodesk.com/t5/AutoCAD-Map-3D/Challenge-to-any-Lisp-guru-to-help-me-beat-my-ESRI-Co-w...
    Don't know if any conclusion was reached
    Dave
    Active Contributor
    05-30-2012 01:29 PM in reply to: parkr4st
    I can not find that there was a decision made.  If there is anyone willing to help with this it would be greatly appreciated.  I know I am not the only person dealing with the situation.
