• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Contributor
    GPS cameras and AutoCAD Map
    181 Views, 3 Replies
    11-27-2008 11:59 PM
    Does anyone have experience of GPS cameras and getting the image or a link to the image into Autocad? I understand that the camera stamps the image's metadata with the co-ordinate location and want to find out if Map can use this metadata to geo-reference the image or place an AutoCAD enitity at the co-ordinate location.
    Thanks in advance for any help.
    Neil
    Please use plain text.
    Member
    Re: GPS cameras and AutoCAD Map
    11-30-2012 09:38 AM in reply to: Neil47
    We are wanting to do the same? Have you found out which camera is best to enable this process? Just starting the research myself.
    antoniovinci
    11-30-2012 11:11 AM in reply to: canaanj
    After 4 years from the first post, I think the OP found it out, sir...
    Anyway, I'm also looking for such a feature, I mean reading the EXIF lat/long coordinates, to put the photos in the right place inside a DWG.
    Valued Mentor
    TerryDotson
    11-30-2012 03:24 PM in reply to: Neil47
    If you were to consider third party software, MapWorks Base will let you select multiple images containing EXIF informatiion and it places camera blocks in the projected coordinate system (image coordinates are lat/long).  If the camera contained a compass the camera block will be rotated in that direction.  A hyperlink is added so you can quickly open the image from the drawing and other photo properties can populate attributes.
