• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    GIS data connection
    301 Views, 6 Replies
    03-12-2012 07:19 AM
    We have this public server in Indiana that I am trying to figure out if Map 3D will connect to.  The directions on how to connect are here:  http://kb.iu.edu/data/aqfx.html
    Can anyone verify / clarify for me if Map 3D 2012 is able to connect to this data?  I cannot get it to work, but I am not a Map / GIS expert by any means.
    Thanks!
    Please use plain text.
    Product Support
    Re: GIS data connection
    03-14-2012 12:34 PM in reply to: clemk
    Hi Clem-
    I would have to assume that if you were accessing this from within the confines of the University's network that you would not need a username/password. Do you happen to know these credentials?
    Additionally since this is a ArcGIS server, ArcSDE would probably be the connection you would use in FDO. Also you may want to try this http://www.esri.com/software/arcgis/arcgis-for-autocad/download.html and see if that helps.
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Autodesk, Inc.
    Being Civil
    Being Civil Twitter
    Being Civil Facebook
    Active Contributor
    03-16-2012 10:20 AM in reply to: SethHall
    Hi Seth,
    Thanks for the input.  I have received this additional information for the public ArcSDE server on this site...
    The account username is :inmap
    The password is:wndrIN2day
    The server name is: inmap.iu.edu
    The instance name is: inmap
    Oracle direct connection uses port:1522
    Application connection uses port:8307
    I have had no luck with Map 3D data connect with this information.  I get an error in Map of "unable to establish connection to provider.  FDO Provider entry point function 'CreateConnnection' returned NULL."
    Would you kindly see if you can utilize this new information to connect to this ArcSDE server?
    Thank you!
    Clem
    Active Contributor
    03-16-2012 11:14 AM in reply to: clemk
    I tried to use the information you provided and failed.  I tried using ArcSDE FDO and WFS FDO and neither could obtain a connection.
    Product Support
    03-16-2012 11:51 AM in reply to: clemk
    By any chance are you runnign a 64-bit OS? If so please see this technical solution: http://usa.autodesk.com/getdoc/id=TS18800464
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Autodesk, Inc.
    Being Civil
    Being Civil Twitter
    Active Contributor
    03-16-2012 01:19 PM in reply to: SethHall
    Yup that would be my problem, I am running 64-bit Windows 7 with 64-bit AutoCAD Map 3D
    Active Contributor
    03-19-2012 06:38 AM in reply to: SethHall
    errr.  I remember that 64-bit issue... now that you reminded me :smileysad:
    Thanks Seth.
