• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    Figuring out scaling....what am I doing?
    454 Views, 7 Replies
    09-20-2010 06:57 AM
    I didn't know where to post this and i have researched on the internet and still don't understand.
    I have always worked with a map that is in Feet and Inches.  We are trying to work with the map in NAD83 now.  My problem is that people ask me all the time the print the map for them in different scales so they can sketch designs on the map.  They like scales like 1/8"=1'-0", 1/4"=1'-0"., 1"=20'-0"....and so on.
    Is there a chart or a place I can find the formula to do this?  Is this possible with a NAD83 Map?
    I would hate to have to keep 2 maps to keep things running.
    Thanks!
    Please use plain text.
    *Expert Elite*
    Murph
    Re: Figuring out scaling....what am I doing?
    09-20-2010 02:57 PM in reply to: wrightsville1
    NAD is a datum not a complete coordinate system as far as units go. Are you using LL83 or a stateplane NAD83 coordinate system?
    Murph
    Supportting the troops daily.
    Active Contributor
    09-21-2010 12:51 PM in reply to: wrightsville1
    state plane NAD83 coordinate system
    *Expert Elite*
    Murph
    09-21-2010 01:55 PM in reply to: wrightsville1
    If everything is in standard fett units then is just simple AutoCAD paperspace setups and vport scaling. Of course you need to edit the scale list and add some scales to it. At 1"-1' on a D size plot you only see about 36 feet of map. You should try using 1''- 100' or greater for mapping.
    Murph
    Valued Mentor
    09-21-2010 03:07 PM in reply to: wrightsville1
    So, with what Murph is leading you to, from Paper Space, check your viewport scale in the lower right corner of your screen when you activate your primary map view.  Here is where you can set the scale.
    Also, make sure you work with a text style that is "annotative" and not hard-set for height (i.e. 10 or 20 drawing units).  Instead, if you work with annotative text, it will automatically scale up to be your determined height on the printed page as a relation to your viewport scale.  This means that you no longer have to maintain 2 or more text layers for your different maps' scales.
    Hope this helps!
    TdH
    Active Contributor
    09-22-2010 12:50 PM in reply to: wrightsville1
    Thanks for your help.  I will try this out :smileyhappy:
    *Expert Elite*
    Murph
    09-22-2010 02:40 PM in reply to: tzzzzoddhepworth4253
    Eeeeeeee.... Annotation scales ........ ONLY as long as you use it for standard auto text/blocks. Using FDO the style settings works better or if you are using Civil 3D stay away from the anno texts.
    Also open up the Viewports toolbar it will let you switch the viewport scale with a click.
    Hope this helps!
    TdH
    Murph
    Valued Mentor
    09-22-2010 06:31 PM in reply to: Murph
    as usual, thanks Murph - I concur - sometimes my train doesn't always reach the station...
    I was thinking about "plain" acad objects and not about feature labels when I wrote my reply.
    Cheers!
    T
