• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Contributor
    Fatal error when using grip to select obect..
    121 Views, 5 Replies
    04-16-2012 08:47 AM
    Crashes
    Please use plain text.
    *Expert Elite*
    Re: Fatal error when using grip to select obect..
    04-16-2012 08:57 AM in reply to: 40032831983
    some questions:
    • What AutoCAD-Map3D release do you have?
    • What Servicepack have you installed for it?
    • Is it reproducable (every time you click an item) or does it appear randomly?
    • What datasource-type do you use? SHP, SDF, SQLite, ....?
    • Where does this datasource com from, what software created this data?
    • Does that datasource contain polygons, arcs, points or mixed data?
    • Have you tried to convert it to SDF and continue that way?
    • Have you tried to connect the data into a new drawing?
    • Have you checked the current drawing with _AUDIT (before and after connecting the data)
    Additional info would bve helpful:
    a) Screenshot from your crash
    b) Data-Upload if you are allowed to show that
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Valued Contributor
    04-16-2012 10:40 AM in reply to: 40032831983
    Program - 2012 Map 3D W/Raster Design SP1,64bit
    Workstation - Windows 7 Enterprise SP1, Dell T5500, E5607, 8Gb.
    Crashes/Fatal error anytime I attempt to select anythnig using grips.. Blocks, plines, text, anything..
    Just started it this morning... Last week everything was great....
    *Expert Elite*
    04-16-2012 10:55 AM in reply to: 40032831983
    try to login to your pc/to your Windows with another user-account, then start AutoCAD-Map .... same problem?
    What has changed on your pc since it was fully functional last time? Any updates from Windows? Was there anything installed in the meantime?
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    04-17-2012 06:24 AM in reply to: alfred.neswadba
    Tryed that, didn't make any disfference...
    Reset the system var "GRIPS" to 0 then back to 1.... Fixed it.. don't know why...
    Weird... but not surprising..
    Thanks for trying to help!!!!
    *Expert Elite*
    04-17-2012 06:37 AM in reply to: 40032831983
    Thank you for the feedback!
    I also don't understand the reason why this helped, but now we know that it's worth to try it! :smileywink:
    - alfred -
    Alfred NESWADBA
