• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    FDO ArcGIS Provider in AutoCAD
    635 Views, 15 Replies
    04-12-2012 07:11 AM
    Does anyone know if Autodesk is working on a 64 bit version of the "FDO ArcGIS Provider in AutoCAD".
    Currently I am only aware of a 32 bit version for AutoCAD Map 2011 & 2012.
    Thank you
    Please use plain text.
    *Expert Elite*
    Re: FDO ArcGIS Provider in AutoCAD
    04-12-2012 07:17 AM in reply to: anadarko
    ArcGIS is a product from ESRI (not a dataserver or fileformat), why should Autodesk create a FDO-Interface to ArcGIS then?
    If you want to access data with both products you can use SHP for example, or you have an ArcSDE-Server.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Distinguished Mentor
    thepworth
    04-12-2012 07:44 AM in reply to: alfred.neswadba
    In other words - E$RI must make it available first.  Start with them - "The squeaky wheel & all that....."
    Best of Luck!
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    *Expert Elite*
    04-12-2012 07:50 AM in reply to: thepworth
    No, that is not what I meant!
    FDO provides the ability to connect to data-servers or files.
    ArcGIS is not a data-server and not a fileformat. ArcGIS is a product that gets data from servers or files and do some analysation then. But it does have no functionality to provide data to any program/interface/....
    Hope now my words are more clear.
    - alfred -
    Alfred NESWADBA
    thepworth
    04-12-2012 07:52 AM in reply to: alfred.neswadba
    O.K. but the .DLL's that FDO relies on (specifically for connecting to ArcSDE data stores / PGDB's / ESRI proprietary forms) are E$RI generated & supplied.  Technically, connecting to an ArcSDE server requires the user have a vaild ESRI software license agreement to put the .DLL's in AD's FDO directory.  Or so is my limited understanding :smileywink:
    C3D 2011
    *Expert Elite*
    04-12-2012 07:58 AM in reply to: thepworth
    >> O.K. but the .DLL's that FDO relies on (specifically for connecting to ArcSDE data stores [...]
    Yep, you are very right for ArcSDE (that is a dataserver I mentioned above).
    For this question here "ArcGIS Provider" it's to say that ArcGIS and ArcSDE are (very) different products! :smileywink:
    - alfred -
    Alfred NESWADBA
    04-12-2012 08:10 AM in reply to: anadarko
    This is the response we received from an ESRI representative:
    The dlls that you are looking for are not from Esri but are included in the Subscription Advantage Pack for AutoCAD Map 3D 2011.  These are used to run the FDO Provider in AutoCAD.  If ArcGIS Desktop is installed on the system, then there is no need for the FDO Provider.  If you have purchased a copy of the Subscription Advantage Pack for AutoCAD Map 3D 2011, then the dlls will be available on those installation disks.  I spoke with another senior analyst on the Desktop SDK Team and confirmed with him that those are not Esri dlls.  Since they are not our dlls, you will have to work with Autodesk to get them.
    Autodesk has supplied the dlls for Map 2011 and are included in Map 2012 but only in the 32bit version.
    I am only asking if anyone knows if 64bit versions are in the works.
    We can already connect to ArcSDE, we are wanting this add-on to be able to connect to personal and File geodatabases (.fgdb & pgdb files)
    Thank you for all the responses.
    Product Support
    04-16-2012 06:34 AM in reply to: anadarko
    There are two separate providers:
    There is the ArcSDE provider, which requires .dlls from ESRI, and is installed by default on x86 and x64 Map and Civil 3D, and has been for some time.  The .dlls do have to match the bitness of the operating system.
    There is also an ArcGIS provder, which only installs on x86 Map and Civil 3D, and is newer - it first was available as a SAP for 2011, and is now in the box.  This provider ships with all required components, but requires a licensed ESRI product running on the same machine - no license available or no ESRI product installed, and you won't be able to use it.  I hope that helps to clarify.
    Nate Moore, GISP
    Geospatial Premium Support Specialist
    Global Services
    Autodesk, Sarl
    *Expert Elite*
    04-16-2012 06:53 AM in reply to: NateMoore
    So I have to apologize, I was wrong, sorry.
    - alfred -
    Alfred NESWADBA
    04-16-2012 08:02 AM in reply to: anadarko
    Thank you all for your responses.
    We have all the required ESRI licenses to be able to utilize the "ArcGIS provider" but we are using the 64bit version of Window7 as well as the 64bit version of map3d. We want to use this in our field offices that have limited bandwidth.
    We are hoping Autodesk will create a 64bit version.
    Thank you again
    Rick
