• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    neilyj
    Exprot joined and queried data to plain CAD
    128 Views, 3 Replies
    06-19-2012 05:15 AM
    I'm finding Map particularly infuriating today......(more so than usual)...!!!!
    I have connected to various shp files and then queried by circle to get my area of interest. I now want to "export" this data as plain AutoCAD entities but can't seem to do it with any success.
    Can anyone point me in the correct direction...??
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    antoniovinci
    Re: Exprot joined and queried data to plain CAD
    06-19-2012 05:41 AM in reply to: neilyj
    Hmm, sounds like you wanna joke with us, man: a power-user with 1630 posts is NOT allowed to ask this kind of questions.. Anyway, let's joke:
    1] _MAPIMPORT those shapes
    2] _MAPTRIM everything by circle
    3] finally _WBLOCK the remaining objects, or SAVE AS dxf rel.12
    neilyj
    06-19-2012 05:57 AM in reply to: antoniovinci
    1630 posts in total - but considerably fewer relating to MAP problems....!!!!
    I've done the first 2 steps: it's getting the shp files data to a CAD format that's causing the problem -  I tried the _mapexportcurrentmaptodwg but nothing is getting exported.
    EDIT - Just tried in  2012 and _mapexportcurrentmaptodwg worked fine on a local drive and have now tried in 2013 with a local drive which also worked fine.
    Conclusion - probable network access issue causing the export to fail..??
    neilyj
    Valued Mentor
    06-19-2012 07:23 AM in reply to: neilyj
    after the connect and add by query. map explorer, right click the layer and export data to sdf.  you can then map import the sdf with create OD  to cad
