• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    alastairworsley1918
    Exporting to SDF - How do I export a polygon with a hole in the middle?
    203 Views, 2 Replies
    11-20-2012 07:22 AM
    My first post here, hoping for a bit of help with something that will hopefully turn out to be quite simple.
    The attachment can probably explain this better than I can, but basically I have a series of polygons for a dataset that I need to export as an SDF. One of these polygons has a hole in the middle which I need to preserve. If I export it as it is, then I will get two polygons, one inside the other that will sit one on top of the other. What I want is to keep it looking as it is there.
    Any ideas?
    Thanks in advance
    A
    Please use plain text.
    Re: Exporting to SDF - How do I export a polygon with a hole in the middle?
    11-20-2012 07:56 AM in reply to: alastairworsley1918
    start command MPOLYGON and convert the polyline to polygons ==> that will (should) recognize the island-polyline as island for the MPOLYGON-object.
    The MPOLYGON-objects can then be exported including these islands.
    The other option would be to first create a topology and start MAPEXPORT with the option to use the topology for export and not the geometry-objects.
    - alfred -
    Alfred NESWADBA
    New Member
    alastairworsley1918
    11-20-2012 08:08 AM in reply to: alfred.neswadba
    Many thanks Alfred, the MPOLYGON command works just fine. I've had to have a closer look at the polylines as one was crossing itself, but that has done the trick for now.
    Thanks very much!
    A
